Check engine light loose gas cap?
Old Sep 1, 2009 | 07:46 PM
scubatelco's Avatar
Default Check engine light loose gas cap?
I have replaced the gas cap,looked all over for a bad hose/connection and still can't stop this CEL from coming back! HELP!!! I even took out the back seat and checked by the gas tank. Does anybody know where to find the relays for the evac system or/and have any clue what the most common cause for this trouble? 2000 S80 non turbo. Thanks before I take a bat this car!
Old Sep 1, 2009 | 07:49 PM
Is the evap valve bad?
Old Sep 1, 2009 | 08:11 PM
scubatelco's Avatar
Default evap value?
Hey Tech where is the evap value and how do I test it? Thanks
Old Sep 1, 2009 | 09:04 PM
The evap valve is mounted to the cooling fan. Take it off and try to blow through the valve. You should not be able to. If you can it is bad.
In the back by the canister there is another valve called a shut off valve it can be bad as well.
Old Sep 1, 2009 | 09:28 PM
scubatelco's Avatar
Default EVAP valve OK
Hi Tech, I goggled volvo evap and I found a thread at volvo forum on the v70 with the same trouble. I just finished removing the evap valve (same place as the v70) and it checked ok . I tested with a 12 volt battery also and it operates just fine. I also cleaned it with brake fluid and put it back in, reset the CEL. I will check the shut off valve if the CEL comes back on after driving it tommorrow. I'll let you know what I find.
Thanks Again for the help.
Old Sep 1, 2009 | 09:52 PM
scubatelco's Avatar
Default one more thing
don't know if this means anything but it seems that this CEL started happening after the right rear speed sensor was replaced by a repair shop. Does the evap hose go back there?
Old Sep 2, 2009 | 03:10 PM
Xkontour98's Avatar
I also have a small evap leak CEL. Are the valves the in the same place on the T6 model?
Old Sep 2, 2009 | 07:11 PM
Yes it is.
scubatelco The canister is on top of the rear suspension so maybe them changing parts might have done something.
Old Sep 3, 2009 | 01:14 PM
scubatelco's Avatar
Default tech
The CEL came back on so I'll check the canster and shut-off vavle. I saw a small can in front of the right rear tire, is this it?
Old Sep 3, 2009 | 06:51 PM
There is a J hose that comes off the canister. On the end of the J hose is the valve.
Old Sep 5, 2009 | 05:05 PM
scubatelco's Avatar
Default buried above rear end
Tech I jacked the car up and can see the canister and the J tube, as well as the wiring connector, but how in the world do you get at it to repair. I can't even get my hand up there, only to touch the wiring connector. WOW! I am guessing this is one for the repair shop to fix?
Old Sep 5, 2009 | 09:38 PM
Well you have to drop the rear suspension some to be able to get the valve out.
Old Sep 7, 2009 | 07:54 PM
scubatelco's Avatar
Tech Thanks for the help. I think I am going to let the experts do this one, too ahrd on the back but a whole lot easier if it was on a lift.
XC90Passenger
Oct 6, 2012 08:43 PM
barinthus
Nov 3, 2011 03:57 PM
leland
Aug 21, 2010 08:03 PM
kwf739
Aug 10, 2010 10:52 AM
elmo_allen
Oct 15, 2009 08:30 PM
