Cleaning My Mass Air Flow Sensors
Old May 4, 2007 | 04:00 PM
Sssnake's Avatar
Default Cleaning My Mass Air Flow Sensors
I've been getting the "Service Engine Immediately" light for a couple of months now, and have been ignoring it because I just know the Volvo dealership is going to charge me a bundle for what I don't know. So after have read through several of these threads regarding bad /suspect Mass Air Flow Sensors, I have decided to try remedy the problem "on the cheap" by first attempting to use the CRC MAFS cleaner. But, alas, I am 'mechanically' challenged!!! Does anyone have the procedures for cleaning the mass air flow sensors, using this cleaner? Do I spray it on or do I pour it down the fuel pipe? If I spray it on, what should I remove to get to the MAFS?
Old May 6, 2007 | 10:57 AM
Default RE: Cleaning My Mass Air Flow Sensors
The mass flow sensor is mounted in the Air Box. It is where the house attaches to the air box. Remove the hose then the sensor and spray the sensor off then let it dry and reinstall.
Old May 7, 2007 | 10:30 AM
Sssnake's Avatar
Thanks, I'll give it a try.
Old May 8, 2007 | 12:59 PM
dynamok's Avatar
Did it work? I'm going to give it a try today as well.
Old May 11, 2007 | 11:40 PM
volvotechky's Avatar
It wont work, just break down and replace it.. cleaning a MAF sensor is pointless
Old May 14, 2007 | 09:28 AM
dynamok's Avatar
I can't tell if it did anything after cleanning. I should receive my reader this week and be able to tell if it worked or not.
movistardave
Jan 17, 2011 11:11 AM
jerryman
Oct 28, 2006 07:35 PM
reg
Jan 1, 2006 11:41 PM
rgarrett
Sep 19, 2005 05:02 PM
floryed
Apr 14, 2005 10:51 AM
