Coolant leaking? Please HELP!
Old Aug 19, 2009 | 07:38 PM
Jordanlyons5's Avatar
Default Coolant leaking? Please HELP!
I have a 2003 Volvo S80 T6. I recently had the fuel pump replaced because the car was not starting. After having that replaced the car runs fine now, however a noticed that my coolant light came on and I was a little low on coolant. So I filled it back up thinking the light would go off but it didn't. I also discovered that I was leaking coolant. What do you think this means? i really would like some help please.
Old Aug 19, 2009 | 07:58 PM
fs's Avatar
fs
One answer...for the light staying on, the float sensor in the plastic bottle maybe bad...You could try just poking the round float thing in the bottle with something, I might be just stuck.
Your other question depends...Where is it leaking from? Could be a loose hose connection, radiator could be leaking, drain **** could be leaking......I know on my 99, the outside plastic piece(outside edges)of the radiator leak...getting worse n worse.
Try to visually trace where its coming from.
Old Aug 19, 2009 | 09:23 PM
andrei3333's Avatar
yeah its really hard to tell you know, you have to investigate, grab a flash light and get underneath the car, look around, also loo around the engine bay
i have seen people on here report bad coolant level sensors with their bottle full, so poking around is not a bad idea
try to find where the leak is coming from
Old Sep 11, 2009 | 02:43 PM
carlover99's Avatar
ALso check if the carpet on the drivers side or passenger side floor. If they are wet, you have a heater core issue that is found under the dash. that one is a pain, I ended up having to replace heater core and took the car for a carpet shampoo and wet vac service.
ohio-brad
Dec 30, 2010 06:37 PM
IsuzuFire
Jul 17, 2010 07:47 PM
MC92
Sep 26, 2009 05:48 PM
1mustang
May 28, 2008 07:27 PM
jonnyboyca
Feb 11, 2008 11:59 PM
