Cruise Control Problem
Old Oct 5, 2008 | 07:03 PM
diehardgator1's Avatar
Default Cruise Control Problem
I can set my cruise and it will work fine for maybe 20 miles more or less it will then just disengage. I can turn the cruise off and start all over again. Any one have any thoughts on this
Old Oct 5, 2008 | 08:10 PM
Default RE: Cruise Control Problem
Thats funny it is all controlled by the computer.
Do you have a check engine light?
Old Oct 6, 2008 | 12:02 PM
NO CIL You can set the cruise go about 20 miles more or less and it just disengages. Turn cruise off and reset it will work again for a while
Old Oct 6, 2008 | 01:16 PM
Maybe the brake pedal sensor or something like that is seeing and intermitent fault.
Old Oct 10, 2008 | 12:25 AM
silencecom's Avatar
funny you should mention.. The other day i was driving along and engages the autopilot button (im talking about the one that just makes "cruise control" display on the panel) but nothing happened... the light didnt come on and i couldnt engage my speed as usual.. I figured it was broke and didnt mess with it anymore.. but later that day it worked fine and has worked since.
Old Oct 10, 2008 | 08:05 AM
I wonder if it is a start of a steering wheel module problem.
Old Feb 6, 2011 | 07:25 PM
shopower's Avatar
I have the same sort of problem...sometimes I will be driving along and the cruise will just shut off however the word "cruise" will still be on the dash. I will have to hold the + button down for along time to get it to come back on if it does at all. Other times I will start the car and no matter how many times I press the cruise button it will not display "cruise" on the dash. If I shut the car off and start it again "cruise" will appear on the dash again. Any suggestions???
Old Jun 13, 2011 | 09:58 PM
shopower's Avatar
Here are the codes... I got the dealer to pull them while doing my SRS module. All the ones with black stars beside them are related to the Cruise issue they said. I am not sure where to start.
CODES
Any help with this would be AMAZING!! calling tech??
In fact any help with any of these codes whether they are related to the cruise or not would be extremely helpful to me...Thanks in advance!
russ
Mar 8, 2017 10:10 PM
rspi
Mar 7, 2010 06:13 PM
steveig
Aug 13, 2009 08:49 PM
Tom.
Jul 21, 2009 04:58 AM
jfikentscher
May 31, 2006 09:58 PM
