does a slipping transmission always mean a new one is needed
Old Apr 28, 2008 | 08:49 PM
worldspeaker's Avatar
Default does a slipping transmission always mean a new one is needed
Have a 99 S80 with 120,000 miles and it just started slipping.Just tookit amile from the house and it made a whistling noise and then wouldn't move. Engine just reved. Made no noise under the hood when shifting from park to drive. Turned it off and then it made the normal noise when it was shifted into Drive. Itthen drove for 100 feet and then just slipped again and had to be towed home. Could this be a computer issue? Would a fluid and filter change help? Is it definatelyneeding a new transmission?
Thanks for the help.
Dave
Old Apr 28, 2008 | 09:14 PM
Default RE: does a slipping transmission always mean a new one is needed
Most likely the tranny is toast.
Old May 5, 2008 | 07:57 PM
Thanks Tech,
This my sound like a stupid question but I have no error codes from the transmission. The dash says "Brake Failure Urgent Service Required". Is it possible that the computer would shut down the transmission because of the brake failure? I know this doesn't sound likely but this car has always had surprises. Just when I think I may understand this car it does something like this.
Thanks again,
Dave
Old May 5, 2008 | 08:15 PM
It is possibly.
Most likely the ABS module is bad. That is why the light is on.
You can get it rebuilt for about $100.00.
Then you can try and see if it helps.
luke8_8
Jul 1, 2023 11:19 PM
dpvovo
Aug 10, 2010 01:40 PM
Dan Larkin
May 21, 2010 03:21 AM
smallslandscaping
Apr 19, 2008 01:45 PM
photomike
Nov 20, 2004 06:26 PM
