DTC SET: ECM & CEM
Old Apr 5, 2006 | 11:02 AM
cruizzzinS80t6's Avatar
Default DTC SET: ECM & CEM
I just did a DTC check due to the check engine/ emissions light, and got DTC SET's for the ECM and CEM. Any idea to what it can be? as I hate bringing it to Volvo where they often just bs around and leave me with an insane bill. The car has been acting strange lately; such as irregular shifting (missing 3rd gear in many occassions where it revs up and seems to just drop) and a sort of "puttering" feeling when the car is stopped at a light. Any help is GREATLY APRECIATED!!!
Old Apr 5, 2006 | 12:32 PM
Default RE: DTC SET: ECM & CEM
also for the hell of it i tried getting the check engine light to go away by holding the odometer button and all i got were the numbers "42" and "58" and the light was still on. Anyone know what these numbers mean? Im only used to fixing mustangs, corvettes, and camaros so these volvo engines are a little bit different.
Old Apr 8, 2006 | 02:47 PM
You will need to use an OBDII scanner to pull and clear codes. But it will only work on the ECM.
You will need a Big setup to read codes from the CEM.
Those are error messages for trying to clear the SERVICE LIGHT.
Those codes mean nothing.
Rdhcincy
Nov 27, 2023 12:04 AM
JenniferXC70
2001-2013 model year XC70
Oct 25, 2022 10:46 PM
onekruss
May 17, 2014 12:42 PM
AEndy
Nov 1, 2013 07:57 PM
Rdhcincy
1998-2000 model year V70
May 14, 2012 01:29 PM
