Electrical Trouble 99 S80 T6 Attn TECH
Hello All,
Fasten your seatbelts and get this. This morning I turn my left indicator on to merge onto the 427. The Indicator wouldn’t go off, IT’S STUCK ON. The hazard switch works and I am driving around downtown with both the blinkers on. I checked further, tried to make it go on by turning and “clicking” the steering, don’t work Left is blinking away to glory. I noticed that the CD Track Skip, volume control, cruise on /off, the message read button. Nothing works. The only thing that works on the 2 sticks is the wipers, but not the water sprayers. So basically the wipers go on and off but I can’t spray water on the windscreen. After about 40 minutes of driving the Lambda (check engine) came on too! But I can’t read the message as the read click doesn’t work. I can notice the panel back lights dim / fluctuate with the blinker I know the dimmer for the panel lights was behaving funny for the past 2-3 weeks But didn’t pay much attention, it would brighten up and dim on its own. I have booked an appointment with Volvo tomorrow. So if some one can offer some thoughts, I would be more at ease walking into The valley of dead!! Thanks for reading guys!! |
RE: Electrical Trouble 99 S80 T6 Attn TECH
Most likely a Bad steering wheel module.
Thanx a million for the Twin Turbo Response TECH !
Youre the man, Question , can i try to reset this module by disconnecting the battery for a while or removing the SWM fuse. Is the check engine light connected to this and will a battery reset take care of that too, or does that require a VADIS reset. Also if all fails i will take it to the dealership. the lady there said it might be a software bug or maybe something more (there usual style give you hope and pull the plug at the same time) how much am i looking at?? ball park? |
Update on the situation.
the car was parked for about 8 hours now the blinker has stopped blinking. the steering controls still dont work, and the passenger front window and lock dont worked every other window and lock works i presume this is connected. and yes the horn works |
most likely connected.
SWM job being done today
530 dollars!! ouch A mechanic at a Volvo shop decides to scare me by saying the “Body Control Module” Can also be the culprit with the door locks and windows not working??? I hope that’s not true and hope, the SWM and the software download nails this sucker!! |
I hope so to.
Keep me posted. |
OK job done got the car back.
2 days later, the LAMDA comes on with nothing else. no yellow triangle , no message, NOTHING!!! i disconnected the battery, connected the 2 terminals together for 2-3 mins and started again, its gone now, but im sure itll be back. it came on when the SWM blew, but i couldnt check for messages as the read click wasnt working. whats this new pain guys!! |
Wait and see if it comes back on.
