Emptying gas tank of Volvo S80
Old Jul 24, 2006 | 03:31 PM
phytopath40's Avatar
Default Emptying gas tank of Volvo S80
The wrong type of gas (ethanol-based) has been pumped into the S80. Using siphon seems futile as the siphon doesn't seem to get into the bottom of the tank. Is there a way to siphon the wrong fuel out? Is it possible to drain the fuel from the bottom of the tank; if so, how do I do it? There seems to be a cap underneath but I might not open it right. Thanks.
Old Jul 25, 2006 | 01:03 AM
Default RE: Emptying gas tank of Volvo S80
About the only way to do it is disconnect the fuel filter and hotwire the pump to drain.
Old Jul 25, 2006 | 05:33 PM
v62cobra's Avatar
You could also use a pump. Did it on a benz that was filled with really old benz. Not a cheap solution at all, but if you have access to a pump that is an option.
dejr
Aug 29, 2019 07:47 PM
chloversokolov
Mar 20, 2014 05:13 PM
michaelm
Jan 1, 2013 12:25 PM
brooklynaut
Nov 11, 2010 07:52 PM
AnEskimo
Oct 7, 2010 07:28 AM
