ENGINE SYSTEM SERVICE REQUIRED MSG
Old Sep 13, 2008 | 06:23 AM
BILL_MCCASSEY's Avatar
Default ENGINE SYSTEM SERVICE REQUIRED MSG
I have engine system service required message but no check engine light. Is there a way to clear it, or is there something wrong? I have held in the button on the end of the directional switch but it does not clear it.
Old Sep 13, 2008 | 07:26 AM
Default RE: ENGINE SYSTEM SERVICE REQUIRED MSG
I found an old thread on this topic that worked.
Old Jul 8, 2011 | 03:49 PM
icmoops's Avatar
can u send me the link of the thread that helped u with the light
Old Jul 8, 2011 | 11:46 PM
BlakTwinT's Avatar
Try unplugging the battery for 15 min. That resets all the electronics including the engine light. This might work for you...
Old Jul 17, 2022 | 05:46 PM
redelllib's Avatar
Default Reset "service required" message
I just cleared the service message on my Volvo C70 after changing the oil using this method. To reset the Volvo maintenance message without a fault code reader and aservice reset tool, do the following:
  1. Put your key in the ignition and turn it to position one.
  2. Next, turn your trip computer to trip one.
  3. Press and hold the trip computer while turning your key to position two.
  4. The center arrow will flash red three times.
  5. On the third flash, you will let go and an alert will note that you justreset your service light.
If the instructions above do not work for you, then you should consider using a service reset tool and a car code reader.
https://www.gunthervolvo.com/how-to-...vice-light.htm
Old Jul 17, 2022 | 06:55 PM
Yes that works for a service light. That warning/light/message comes on every 5000/7500/ or 10,000 miles depending on what your cem is set to. That's an oil change light.
An engine system service required message means there is a self diagnostic code stored in usually the ECM. To reset it requires reading the code with a scan tool and erasing it, the same as when the check engine light is on.
michc927
2001-2013 model year V70
Feb 3, 2014 06:02 PM
ljw8993
Feb 5, 2011 02:28 PM
greatbigwave
Jul 19, 2009 09:20 PM
volvo s80
Oct 24, 2007 11:49 AM
OBXwahoo
Apr 20, 2007 03:45 AM
