Evap Check Valve Question
Old Nov 17, 2008 | 12:47 PM
spunkymonky's Avatar
Default Evap Check Valve Question
Can anyone tell me what problems I might have if one of the check valves is not in place?
The reason I'm asking is one snapped and apparently you have to buy the whole hose assembly from Volvo to get the check valve($90) and I can't seem to find a generic one that will fit. The mechanic at Volvo told me I could just use a straight pipe til I find one and it shouldn't be a problem. He said the check valve was mainly there to keep vacuum at the brake booster once the car was shut off.
[IMG]local://upfiles/17751/513924FACF0147C59DDA3600D5781109.jpg[/IMG]
Old Nov 18, 2008 | 06:13 PM
Default RE: Evap Check Valve Question
It shouldn't mess with the car much.
I used to have just the valve part number at work for just the valve but I am not there to see if I still have it.
Look up in Vadis for a 2000 S40 intake system I believe they use the same valve there try that.
Old Nov 18, 2008 | 08:29 PM
Thanks for the heads up on the s40 part. Looks like 1275226, will order that and see what I end up with.
I replaced it with a tee for now and it seems to work fine so far.
Thanks again.
Old Nov 18, 2008 | 08:41 PM
Let us know how it goes.
Xtr
Jul 11, 2015 11:47 PM
V7022
Mar 28, 2010 10:35 AM
cordoba
Nov 18, 2009 08:09 PM
960 rookie
May 15, 2008 06:06 PM
bal9798
Jun 27, 2006 11:56 PM
