Fuel Filter
According to maintenance schedule, I need to replace the fuel filter.
Questions: Can I use the Bosch brand? Secondly, anything special I need to do? I have Vadis and it looks easy enough. Thanks in advance. |
found filter
IPD had it for $22 with shipping. Hell of a deal.
Bosch is the OEM for this filter actually, just be sure about which filter your car has.. the early model s80's had a longer fuel filter than the later models
Make sure you have a small catch under it and that you make real sure that you get it on and the fitting "clicks" on install... or you get what I got:
Start, run, idle... POW! and I'm pumping gas on the driveway... ;) |
Fuel filter is probably the easiest thing to install on the s80. I didnt even use jacks.
