Fuel Filter
Old May 28, 2009 | 08:52 AM
apfurste's Avatar
Default Fuel Filter
According to maintenance schedule, I need to replace the fuel filter.
Questions:
Can I use the Bosch brand?
Secondly, anything special I need to do? I have Vadis and it looks easy enough.
Thanks in advance.
Old May 28, 2009 | 09:09 AM
apfurste's Avatar
Default found filter
IPD had it for $22 with shipping. Hell of a deal.
Old May 28, 2009 | 12:23 PM
nicolaselias's Avatar
Bosch is the OEM for this filter actually, just be sure about which filter your car has.. the early model s80's had a longer fuel filter than the later models
Old May 28, 2009 | 06:02 PM
75ohm's Avatar
Make sure you have a small catch under it and that you make real sure that you get it on and the fitting "clicks" on install... or you get what I got:
Start, run, idle... POW! and I'm pumping gas on the driveway...
Old Jun 13, 2009 | 09:46 PM
apfurste's Avatar
Fuel filter is probably the easiest thing to install on the s80. I didnt even use jacks.
timoc663
Aug 14, 2016 05:35 PM
inilegna
Sep 25, 2013 03:27 PM
smithnr
Apr 8, 2013 04:56 PM
CoVoVo
Oct 24, 2012 10:19 PM
AnEskimo
May 15, 2011 12:32 AM
