headlight and fog light problem
Old Apr 11, 2009 | 10:15 PM
neill1223's Avatar
Default headlight and fog light problem
The headlight and fog light on passenger side both quit working.
Have checked fuses for them, have also just replaced shunt as both headlights had recently quit working.
any help on this would be greatly appreciated.
Old Apr 11, 2009 | 10:17 PM
You checked both sets of fuses?
There is one in the fuse box in the dash and one under the hood in the fuse box.
Old Apr 12, 2009 | 10:21 AM
neill1223's Avatar
yeah checked both sets of fuses.
Old Apr 12, 2009 | 10:22 AM
Do you have power to the headlight assembly at the main plug?
Old Apr 12, 2009 | 10:26 AM
neill1223's Avatar
that i am not sure on, the high beam does work on that side and i do have a low beam bulb out msg.
Old Apr 12, 2009 | 10:38 AM
Check for power with a testlight.
Old Apr 12, 2009 | 12:14 PM
neill1223's Avatar
no power to lights.
is there a relay that i could check other than the shunt and fuses?
also why would 1 fog and 1 headlight work and not the other?
Old Apr 12, 2009 | 12:58 PM
That is a strange one with the foglight.
There is a relay but I have to find the exact location. There was also another post with the same headlight issue that had diagrams in the post.
Old Apr 15, 2009 | 07:35 PM
neill1223's Avatar
gonna look into that relay. in the mean time when i have time i am gonna wire in a set of HID lights. thanks for the help tech.
andys90
Nov 7, 2012 09:36 AM
Pcar993
Oct 10, 2012 10:07 PM
spankey
May 13, 2010 07:34 PM
picnic39
Jun 9, 2009 06:04 PM
