Horn Fuse Blowing 2004 S80
Old Jan 13, 2011 | 03:20 PM
wamcneil's Avatar
Default Horn Fuse Blowing 2004 S80
So now my horn fuse is blowing. I replace the fuse, and the horn blows weakly and then the fuse pops again. Should I be looking at the horns themselves, something in the steering wheel, or somewhere else?
Anybody else had this problem? I searched, but didn't find any s80s reporting this issue.
Thanks,
Walter
Old Jan 14, 2011 | 09:23 AM
wamcneil's Avatar
Bump...
Any ideas folks?
Old Jan 14, 2011 | 10:07 AM
jlewisinsyr's Avatar
At a loss, just sounds like a random issue (definately not specifically related to Volvos). I'd say, I'd start by looking at the horn, check the connections, make sure the wires are clean and not grounding out (causing the fuse to blow).
What would concern me is if it's the clock spring that has a frayed wire in the steering wheel. Was the car ever in an accident where the front airbag deployed?
Old Jan 14, 2011 | 10:41 AM
wamcneil's Avatar
Thanks. No accidents.
The horn grounds through the clock spring though, right?
Old Jan 19, 2011 | 04:39 PM
wamcneil's Avatar
Ain't got no headlight wipers!
Old Jan 19, 2011 | 07:14 PM
mkc70's Avatar
Thanks,
Walter
Unplug the horns, replace the fuse, press the button. You'll have an answer quickly.
duggantm
May 13, 2009 07:55 PM
kcpaz
Apr 11, 2009 01:18 PM
tbenner
Feb 20, 2008 11:09 AM
macdogd
Dec 25, 2007 09:27 PM
mrchuck85
Feb 28, 2007 09:08 PM
