How to Replace Door Actuator?
The drivers door actuator has gone bad on my 2000S-80. I got the new part and started removing the old actuator and ran into a problem. There is a guide for the window that the actuator is under. The bottom of the guide is attached with arivet, but I can't get to the top of the guide to remove whatever is holding it in place. Do I have to remove this guide or will the actuator slide by it? I am also having problems removing the wire from the actuator. Does anyone have anything to show me how to remove this?
RE: How to Replace Door Actuator?
Did you drill hte rivet out?
If not you need to. The the guide will come out. |
