How to Replace Door Actuator?
Old Jan 5, 2008 | 11:35 AM
HRoberts's Avatar
Default How to Replace Door Actuator?
The drivers door actuator has gone bad on my 2000S-80. I got the new part and started removing the old actuator and ran into a problem. There is a guide for the window that the actuator is under. The bottom of the guide is attached with arivet, but I can't get to the top of the guide to remove whatever is holding it in place. Do I have to remove this guide or will the actuator slide by it? I am also having problems removing the wire from the actuator. Does anyone have anything to show me how to remove this?
Old Jan 5, 2008 | 12:54 PM
Default RE: How to Replace Door Actuator?
Did you drill hte rivet out?
If not you need to.
The the guide will come out.
stop_at_willoughby
Oct 17, 2011 07:10 AM
problematique
Jul 6, 2011 10:37 PM
m1miata
Oct 11, 2010 07:52 AM
djais1801
Sep 7, 2010 11:44 AM
Todzilla
Feb 15, 2010 05:07 AM
