How to replace fuel filter?
Old Jan 26, 2007 | 02:51 PM
go2sharks's Avatar
Default How to replace fuel filter?
Now that I got the parts. Please give me advice if any for replacing the fuel filter.
I haven't look, but this is under car around the right rear seat right?
How much fuel do I expect it would discharge when I remove the hoses?
Old Jan 26, 2007 | 09:02 PM
Default RE: How to replace fuel filter?
The filter is held into the clip with a 12mm screw.
You will push a button then pull the hose off.
The best time to do it is after the car has been sitting a while less pressure.
Would also be good to release the pressure.
You could do that at the fuel rail under the hood.
You will get about a cup or so of gas when you remove the lines.
newmex999
Nov 30, 2013 03:38 PM
smithnr
Apr 8, 2013 04:56 PM
Ahmed
Nov 6, 2010 02:06 AM
redondotom
Mar 30, 2009 07:40 AM
petes99xc
Dec 2, 2006 01:41 PM
