how to turn off low beam light on 2004 S80 Volvo
Does anyone have an idea on how to completely turn off the headlights? Their always on no matter which setting you select. (with the ignition on):
I wanted to turn off it when light switch is turned to 0. I google this and found using the following way, unfortunately it does not work for my car, anything else I have to try? put light switch to the Center position , (sidelights > Green LED ON) Switch ignition key to position II (Drive, but Do Not start the engine) Pull Main beam lever towards you and Hold it there, Turn light switch to 0 release main beam lever If you could provide help, I would appreciate it. thank you very much. |
It needs to be programmed by the dealer or someone with VIDA
