how to turn off low beam light on 2004 S80 Volvo
Old Jun 28, 2016 | 06:28 PM
bill922's Avatar
Default how to turn off low beam light on 2004 S80 Volvo
Does anyone have an idea on how to completely turn off the headlights? Their always on no matter which setting you select. (with the ignition on):
I wanted to turn off it when light switch is turned to 0. I google this and found using the following way, unfortunately it does not work for my car, anything else I have to try?
put light switch to the Center position , (sidelights > Green LED ON)
Switch ignition key to position II (Drive, but Do Not start the engine)
Pull Main beam lever towards you and Hold it there,
Turn light switch to 0
release main beam lever
If you could provide help, I would appreciate it. thank you very much.
Old Jun 28, 2016 | 06:40 PM
ES6T's Avatar
It needs to be programmed by the dealer or someone with VIDA
Old Jun 30, 2016 | 04:11 PM
donf's Avatar
http://www.matthewsvolvosite.com/for...p?f=11&t=76447
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
jw144
Oct 10, 2013 09:31 PM
nemotode
Aug 30, 2011 04:05 PM
drew.johnson81
May 1, 2011 07:48 PM
volvo40_2k
Jul 28, 2009 09:18 PM
