Ignition Coils or Spark plug issue?
Old May 15, 2012 | 11:25 PM
lolxluigi's Avatar
Unhappy Ignition Coils or Spark plug issue?
I own a 2000 Volvo s80 t6, a few days ago I decided to wash the engine with the hose, I let the car running while doing that and after let it run for about 5 minutes. When I shut the car off and turned it back on the car ran rough. I replaced an ignition coil and fixed it for a day then the next day another ignition coil went out. I replaced it and was working fine until I noticed it started shaking again. I'm not sure if another coil is going out again because all it does is run rough when the engine is idling or going in reverse. At high speed it runs normal Please help :/
Old May 24, 2012 | 03:32 PM
PieceKeeper's Avatar
I've encountered this on two occasions myself and decided for the future to be very careful about spraying water near the top of the engine. My situation cleared itself once the water evaporated. But if you do have a bad spark issue, a code reader will tell you which coil/cylinder combo is at fault. To verify if the coil is bad, first get it dried out, then swap with another coil/cylinder and see if the error travels with it.
If you are misfiring at low RPM, chances are good it's happening at higher rpm but the vibration becomes less noticeable at higher rpms. Misfire is not good for the emissions components, also tends to heat up the exhaust manifold more than it normally should be.
Old May 24, 2012 | 07:22 PM
charlesd's Avatar
I have a misfire on my 99 s80 T6 on coil #1 with P0301 with emissions code. I have swapped coils, read the voltages with ignition on and at idle(2.5 for signal wire and 14.0 for hot wire), I have removed the coil and checked with a new plug while engine running. No spark from the #1 coil no matter if swapped with a functioning coil. I'm at a loss about where to look next.
Old May 25, 2012 | 11:40 AM
lolxluigi's Avatar
Alright I got my codes checked and it turns out I had a multiple missfire. Probably caused by three coils that went out at different times. I've replaced one drove for a few miles and the next one blew ou. So far on the 3 rd one its driving well. What is odd is they blew out in order starting with #3 and ending with #5. Hmmmm.....
Old Nov 21, 2012 | 02:28 PM
DPG's Avatar
DPG
Default How many coils?
How many coils will end up being replaced? Do you just replace the one coil that misfires and then when the other fail you replace them too?
Before learning about the misfire issue I have now (05-S60) I replaced plugs and the fuel filter because of loss of power under a load, but then had someone check it only to find I had a misfire on coil #1 so I replaced the coil (boneyard), now 1 day later the misfire is on coil #3. Do I just keep replacing coils? Any help would be appricated.
Old Nov 25, 2012 | 06:57 PM
75ohm's Avatar
BTDT...
I have 3 old spares I think... if you're interested in them, PM me. Came off a 2000 S80 non-turbo.
Old Nov 25, 2012 | 07:12 PM
Coils will last xxx,xxx miles and they'll fail one after the other. Just keep replacing them with new ones if you can afford it. IPd and FCP sells the new OEM ones for under $60.
Old Sep 10, 2020 | 11:51 AM
Jayl161980's Avatar
S60 with same issue but no misfire. Replace all coils and the plugs and see if that helps. Old coils had putty around them. Wonder if same thing happened and that was their fix. Ive had to replace 3 already and only had the car going on 2 yrs. Its running now but all these horror stories are not what i want in my future!
Old Sep 10, 2020 | 06:17 PM
donf's Avatar
Why open a 8 year old thread?
3 coils on a 2 year old car? That's very odd. Generally I would suggest just replacing all the coils at once since they all have pretty much identical wear and tear and if one went. It's like replacing a flat out tire when all 4 have 80,000 miles..
Old Sep 10, 2020 | 06:36 PM
Jayl161980's Avatar
I havent had the car that long. Once the first 2 happened i found putty around 3 of them. Tested all with a volt meter and the rest didnt have putty and tested fine. All 3 with putty failed. Kinda strange but with them costing 60 bucks ea and there are 6. You can do the math. Had to replace sparks plugs also. Just needed to get it back on the road as is my daily!
also nobody cares if it is 8 yr old thread as my problem is happening now.
Old Mar 18, 2022 | 06:07 PM
Alix01's Avatar
My 2000 s40 has the same problem. Low rpm or high tpm shakes whole front badly . I just take out the spark pligs out look like gap is to much. Is that be the problem ? I had change the coils 1 year ago .os anybody can trll me what is gap suppose to be .
strangedays
Sep 13, 2020 03:28 PM
Brian401
Jul 3, 2020 12:34 PM
537playing
Apr 15, 2017 03:07 PM
jtruong3899
Jul 20, 2015 03:28 PM
trooperone
Mar 7, 2009 03:34 PM
