Repeated Ignition Coil Failures
Old Jul 2, 2020 | 09:15 AM
Brian401's Avatar
Default Repeated Ignition Coil Failures
I have a 2003 S80 with 125,000 miles
Last year I had cylinder 6 ignition coil fail (misfire read on scan) - replaced with a NAPA coil (replaced plug at the same time). Eleven months later, same coil failed (replaced under 3-year warranty) - four months later, the same coil failed...so, it is not a coil issue. Trying to figure out what the "something bigger" issue is...
Appreciate any insight...
Old Jul 2, 2020 | 03:59 PM
did you ever check your system voltage? are you sure its the coil and not the wire harness/connector going to the coil? Next time one fails, try swapping coils between cylinders to see if the misfire moves with the coil.
Old Jul 2, 2020 | 08:29 PM
Brian401's Avatar
Thank you for the response. I have monitored voltage. It is fine.
Old Jul 3, 2020 | 12:34 PM
when I started getting random misfires on my 2000 S40, I replaced the wire harness (from the firewall to the coils) and that cured it for good. Best to inspect the connectors to the coil looking for cracks and any other fails like in the covering/insulation
lolxluigi
Mar 18, 2022 06:07 PM
Ricardito
Aug 14, 2012 08:29 PM
vinnyman72
Jan 27, 2011 08:11 PM
fredbyte
Aug 26, 2008 11:17 PM
vikkum
Jul 14, 2008 12:55 PM
