Ignition Switch
Okay, Tech (or anyone who can help). I had my ABS Module replaced, the throttle body cleaned, and the Ignition switch...switched. They told me I was having problems with it. I didn't argue and said "ok, change it." It was only another 125 on the already 1200 bill. I had them change it and then It started giving me problems. The dealership is an hour away and I don't have the time or the means to take it there. Can anyone give me instructions on how to install the old swtich back into the steering column?
RE: Ignition Switch
The top cover will just pop off when pulled up on. Then remove the 3 t-25 screws from the bottom cover and slide off. Then you should see it on the left side of the column. Remove the plug and the 2 screws and swap.
