Ignition Switch
Old Feb 10, 2006 | 01:14 AM
JCVolvoS80's Avatar
Default Ignition Switch
Okay, Tech (or anyone who can help). I had my ABS Module replaced, the throttle body cleaned, and the Ignition switch...switched. They told me I was having problems with it. I didn't argue and said "ok, change it." It was only another 125 on the already 1200 bill. I had them change it and then It started giving me problems. The dealership is an hour away and I don't have the time or the means to take it there. Can anyone give me instructions on how to install the old swtich back into the steering column?
Old Feb 11, 2006 | 05:41 PM
Default RE: Ignition Switch
The top cover will just pop off when pulled up on. Then remove the 3 t-25 screws from the bottom cover and slide off. Then you should see it on the left side of the column. Remove the plug and the 2 screws and swap.
Ricardito
Aug 14, 2012 08:29 PM
roytoronto
Apr 26, 2009 10:59 AM
roytoronto
Apr 5, 2009 09:04 AM
