Intake manifold noise
#22
What's it look like when running?
Something just doesn't seem right if you really hear noise and you're not throwing a misfire code...
Hmmm... a thought... not that our cars are easy to diagnose injectors while the car is running, but did you take the intake plenum off? I ask because you could have an injector issue.
Pull the plenum and check the connections?
#26
#28
My engine also has that exact same clacky sound to it. Coils/ plugs are new and no misfires. I have a lot of dash shaking and unresponsive throttle action but I'm sure that's from the bushing being completely worn on the torque stabilizer. I heard that the sound could be lifters/tappets/ sump seal issues..
I also recently did the breather box and hear some small hissing. What are some performance or visible signs of a vacuum leak to the UIM?
Thanx. (Sorry for the hijacking)
#30
Mobile One full synthetic 30(weight wise I'm pretty sure its 30) two weeks ago.
I'm still unsure if there's a hiss or not going on from when I did the breather box, and I think the clacking may be the sump (not sure).
#34
Cleaned the ETM when I did the swap on the breather box. Torque mount bushing is completely disintegrated though and I just looked at my air box... Its warped and the clasps are missing so that might account for some bad fuel/air ratio setting off a misfire or it could just be the torque stabilizer (for the shuddering).
When I apply even pressure to the accelerator at about 2k rpm the needle goes about a half step up but then falls back to 2k and struggles. If I stomp on the accelerator I get the torque mount shudder but smooth tach to 3.5k forward...
#36
#38
I checked the timing belt while the car was running and it seemed fine. No flap in the belt as far as I could tell. I got side-tracked by yard work so I didn't get to check much else after changing the oil.
Assuming eeuroparts finally gets around to shipping my new oil trap, I am going to disassemble much of the engine bay this weekend. I am going to replace all of the gaskets on the intake manifold and all of the vacuum hoses. I'll check the fuel injectors while I have all of that disassembled. I also have to replace my hood release cable- that looks like fun.....
Is there anything else to check on? I am starting to worry that my alternator is going. Upon start-up I have begun to notice a power drain in correlation to the high revs.
#40
New developments:
eeuroparts is now telling me they won't have my oil trap until THIS Monday (why does that sound familiar?) Going on three weeks now....
So that will have to wait a little longer. In the mean time, my car has changed it's start up habits. Before- it would rev up above 1200 and slowly climb for a few seconds before dropping back down to 1000 (500 if warm). Now the climb up is extremely abrupt- as in I don't think the tach can keep up. It revs up high and fast and drops just as quickly. I have also noticed, especially at long stop lights, an intermittent "shudder" coming from the engine.
