Jacking points on S80
Old Apr 11, 2009 | 04:43 PM
nicolaselias's Avatar
Default Jacking points on S80
I don't normally do much of the work on my car for myself but I wanted to begin with some basics.. Considering that Jacking the car correctly is absolutely essential, I wanted to make sure I knew what I was doing before I did.
Using a standard rolling floor jack, where would I want to jack the car from (front) and where will I want to put the jack stands. Any tips to make it easier/safer?
I understand that the car weighs about 3700lbs, so I am assuming a 2ton jack will be fine, but I wanted to double check that with you all.
Thanks
Old Apr 11, 2009 | 08:56 PM
JTapper's Avatar
I jack at the factory jacking point, and put jackstands at the front and rear subframe mounts.
Old Apr 12, 2009 | 07:52 PM
75ohm's Avatar
brianb
Jul 26, 2014 03:58 PM
admasters
Jan 12, 2014 08:20 PM
bertelsen
Volvo C30
Oct 29, 2009 09:58 PM
Balvenie
Jul 17, 2009 10:42 AM
bw77
Apr 26, 2009 05:54 PM
