loosing power on low gears
I have a 2001 s80 t6. When I come to a stop the car starts to vibrate or skip forward a lil.. and few times died on me when I was on a light or parking lot. starts up just fine and accelerates good.. I was thinking it might be the spark plugs but i have no check engine light or anything.. anyone know what it might be?
Your Electronic Throttle Module is bad. You can find a non contact aftermarket ETM repair on the internet that keeps these problems from ever happening again.
http://www.xemodex.com/ i haven't done it yet, but there are YouTube videos where people had positive results, it just costs 600 bucks and i'm not there yet. I have the exact same problems as you right now. |
are any of the dash lights on that were not on before ?
thanks... that does sound like the problem, i was thinking that may be the problem cause thats what regulates the rpms and the flow..
No, none of the lights are one, check engine doesn't come on or anything, otherwise I would have just plugged it in and ran diagnostics for it.. |
dont all the lights come on with a bad etm ? or is that the case with a bad abs module ?
no the lights don't come on for the etm...
If the ETM gets bad enough it should throw a code, in fact this is a prequsite for the ETM software recall I believe. Does your inlet manifold have a yellow sticker on the bottom of it?
PCV service and a set of copper spark plugs are worth a try IMO. Maybe consider cleaning the throttle body as well if it is gunked up. ETM failures are a certaintly with the S80's it seems, but still I would be checking the basics first before I go dropping $600 on it. If you dont know when the plugs were done last, you might as well do them. Make sure you gap them to .028". They are super cheap (<$3 each) and usually need to be done every 35K miles, or less depending on how much time you spend on boost :D |
the software update was a recall from years ago, it would cover any check engine lights and has most likely been done. as you and i both know by now, the software update is total crap. it gives your car 5,000 more miles at best and most people that get it end up rolling right back to the stealership and getting another new (but broken!) ETM that will fail eventually. if you want to fix your car, never go back to volvo. find yourself a certified mechanic or do the ETM repair yourself (requires you to take it out and send it off, and put it in again, probably 6 labor hours at dealer). the yellow sticker means replacement ETM by the way, no software update gives anything a new colored sticker. I've had the update but no new ETM and mine's still white.
Originally Posted by N_Vagrant
(Post 209021)
On top of the stalling, engine dying on low rpms and vibrating, now my engine light came on. got the "cylinder 4 misfire" code come up.. Is that related to the ETM not working properly or is that a seperate issue?? I'm Planning on exchanging the ETM within a week or 2(and spark plugs, filters) and was wondering if I may also have other issues..
Swap the coil (maybe plug too) on cyl# 4 with another one and see if the code moves to that cylinder. If it does, you need to replace that coil (or plug). Im optimistic that a tune up will help.
A misfire code on a certain cylinder is unlikely to be caused by a ETM issue. |
Check engine light with stalling and or "jumping" before stall
I had a similiar problem with my s80-T6 2001 has 212,000. I was told I was experienceing result of of some "blow pass" Oil getting into places it shouldn't. Any way I milked it along until it finally gave out on me last week. I am still waiting on the estimate and declaration of damage. Not sure if Last Rights are in order or an engine swap... any thoughts?
