multiple codes on '99 s80 T6
I am getting multiple codes (P0113, P0118, P0238) all associated with ecm pin #60. I have replaced the coolant temp sensor and the air intake temp sensor, but the codes remain. Any suggestions?
It's an Innova scanner. No problems clearing the codes. They return after the engine is restarted and the temp gauge is not working on the inst. cluster. All the affected sensors are on the #60 ground terminal.
This may sound funny but it might also help.
Run a ground wire from the transmission to the engine and see if it helps.
The cars main ground goes through the tranny.
If something is wrong between the mating surface it might cause these problems.
I ran a ground from the transmission to the engine with no improvement. I also tested the volts and ohmsat the temp sensor, map sensor and intake air temp sensor. They were within range.The temp gauge isstill not working. Ialso noticedwith the car was running that the a/c compressor did not come on.
Tech, Thanks for your response. I think I need to upgrade my scanner. I do have a question. The VADIS wiring diagram has a connector point 53/319 in the engine wiring harness. The ground wires to involved sensors converge at this connector. Is this an actual connector point outside the ECM ordo the grounds merge a A60 pin on the ECM?
Tech, Thank you for your response. I found the connector(actually a junction point). I also checked continuity of all four sensor (from the plug to and after the junction point) ground wires. All were within specs. The signal is getting to theecm from the sensors. I just don't know what's happening in the ecm.
