need help with brake light always being on
i have a 2001 valvo s80 with outside brake lights always on. the third brake lamp works when pedal is pressed. so i assume switch is good. can some pleaase help. thank you
You'll want to check the brake light relay. Look in the trunk behind a panel on the left side. There are relay diagrams on-line that will assist you in finding the right one. Most of the modules are identical, so you can test your module by swapping it with another that is known to work.
The brake light relay gets a lot of use, so it's one of the first to fail. With frequent use, the contacts inside the relay can form 'pits', that grow larger over time. Eventually, the pits will bridge the contact, and your lights will be stuck on. The problem can be intermittent at first, but it will get worse over time.
You could pry open the relay and clean the contacts, but a new replacement relay is reasonably cheap to buy. If your Volvo is starting to have this problem, you might consider ordering a spare or two.
M
M
Incursus
Jul 9, 2015 01:48 AM
tiggerbren
Mar 11, 2012 08:52 AM
lghyams
Sep 14, 2009 04:45 PM
