Need help with P0101 code
Old Mar 28, 2012 | 07:58 PM
Steemax's Avatar
Default Need help with P0101 code
Before I begin, I searched inside and out, read through all the explanations of the code. I realize the easiest thing to do is just replace the MAF
sensor with said code, but I'm not made of money
The car is a 2000 S80 2.9L (completely stock)
Alright so according to OBD-II Trouble Codes - DTC Codes Car Repair P0101 is "Mass Air Flow (MAF) Circuit Range/Performance Problem".
Now my symptoms are an intermittent unstable idle, complete loss of top end power, (I'll floor it, and the RPM's will slowly climb, they'll climb smoothly without any hesitation, but the car will barley go anywhere.)
Now, here's what I've checked. I've checked the air filter, seemed a bit dirty but can't see it causing this. I've cleaned the MAF with a MAF cleaner. checked the wiring to the MAF as best I can with the naked eye. and checked the vacuum hoses to the best I can.
Is it safe to say the MAF sensor is failing? Or does anyone out there have anything else I can try?
Thanks!
Old Mar 29, 2012 | 01:48 PM
Falasi4's Avatar
Can you clear the code and see if it comes back or changes anything?
Old Mar 29, 2012 | 03:11 PM
Steemax's Avatar
I tried clearing the code, so far it's not back but the symptoms are still there, nothings changed.
Old Mar 29, 2012 | 04:26 PM
Quick Dent's Avatar
Default Vacuum leak
Hello, i had a similar problem on my '97 960 with the 2.9 engine, had several codes and CEL coming on. After researching and testing i found the intake gasket leaking, so i replaced it and engine runs great now.
Gasket cost me $7.00 at local Carquest plus labor, which looks more difficult than what it really is,saved me a lot of money and guesswork.
Newport_j
Apr 21, 2015 11:21 AM
Jarren G Brown
Feb 23, 2015 04:28 PM
Cuazi Modo
Nov 11, 2013 08:11 AM
Cuazi Modo
Nov 10, 2013 10:26 PM
curtis.elrod
Jul 20, 2010 01:10 PM
