OBD2 Scan Tool
Old Feb 13, 2008 | 08:47 AM
magak2572's Avatar
Default OBD2 Scan Tool
Hi Guys. I do not yet own an OBD2 scan tool. I have been looking around on e-bay and have my eye on one. I have heard that not all scanners will work with Volvos. I am wondering if any of you out there have any advice on purchasing the tool.
What I have in mind is the U581 (http://www.alpha-bid.com/product68.html). It is about $100. If it does what it claims it will extract codes, clear the trouble light and also give you some real time display. From what I understand the tool for Volvo needs to use CAN BUS, ISO 9141 protocol.
I am wondering if any of you out there have any advice on purchasing the tool. Of course I don't want to spend hundreds but I think up to $100 is not unreasonable (will pay for itself in saving 2/3 trips to the dealer!).
Thx, George
Old Feb 13, 2008 | 05:51 PM
Default RE: OBD2 Scan Tool
I believe that one will work.
Old Feb 23, 2008 | 11:40 AM
1999S80T6's Avatar
1999 S80 T6
How about this?
http://fcpgroton.com/volvocodereader.htm
Though it is more expensive than the one selected by 'magak2572', I am going for this coz it gives detailed info that can be understood by a noob like me.
And, my dealer charges $120 just to pull out a code and my car is like a random code-generator; I am sure thiswill pay itself in the next month.Since it is sold by FCP-Groton, I am trusting this gizmo.
Thanks.
Old Feb 23, 2008 | 02:34 PM
magak2572's Avatar
Well, I went and bought it. Works like it should - I think. Gave me the codes I was looking for - cylinder misfire/bad coil. Also gives live data while the engine is running + a bunch more (computer software etc.) I haven't figured out yet. Clears codes as well. For newer Volvos they must be CAN BUS capable.
Old Feb 24, 2008 | 12:29 PM
1999S80T6's Avatar
I am looking at Equus 3110 & Equus 3130. The difference between these two is, 3130 can "View and Record Enhanced OBD2 (1996 and above) Live Data".
How is this "live data" useful? Is it worth it to pay $40-$50 more for this feature?
magak2572:
The UIF Tech U581 you bought also has the "live data" feature. Did you try to use it? Is it helpful?
Thanks, guys.
Old Feb 24, 2008 | 03:59 PM
It will be very helpful you can make sure the O2 sensors are sweeping ETC.
Old Feb 24, 2008 | 05:04 PM
1999S80T6's Avatar
OK, then in that case I will go with 3130 with 'live data'. Thanks for helping me make up my mind.
Old Mar 8, 2008 | 09:21 PM
intravino's Avatar
You can check out these guys for obd2 scanner and cables plus connectors:
http://www.carplugs.com/
Old Mar 14, 2010 | 05:50 PM
M@rcel's Avatar
Does the U581 clear SRS/ABS codes on my S80 MY2004?
Old Mar 15, 2010 | 01:27 AM
JVC's Avatar
JVC
ScanGauge or nothing...
Old Mar 15, 2010 | 03:12 PM
Xkontour98's Avatar
I would be interested in knowing this info as well....
TONY12340
Dec 29, 2013 02:42 PM
kennedy759
Sep 10, 2010 05:58 AM
ecberr
Dec 17, 2009 11:08 AM
autowizzard
Sep 25, 2009 10:40 PM
antivole74
Dec 29, 2006 11:58 PM
