the official start off...
Old Sep 21, 2009 | 09:55 PM
gordon368's Avatar
Default the official start off...
I changed my spark plugs a while back (3 months ago), with NGK's and they are working great. But Lately, its taking extra hold for it to start so if there is usually five clicks then start, it takes 10 now. Im wondering if there is something wrong? The plugs when put in were set to the right mm but I didnt have a torque tool so I tightened them to ask much force it was to loosen the original ones.
Old Sep 22, 2009 | 05:40 AM
jlewisinsyr's Avatar
It could be your starter or battery too.
Old Sep 22, 2009 | 04:51 PM
andrei3333's Avatar
your starter is likely on the way out
has nothing to do with the plugs
Old Sep 22, 2009 | 08:36 PM
gordon368's Avatar
sometimes when I remove the key from the ignition, the key is very hot which I am thinking its not normal.
Old Sep 23, 2009 | 05:57 AM
Do you have an aftermarket alarm or remote starter? If so, the connections could be shorting out (sometimes people install the connections up close to the ignition switch), otherwise, I'm not sure there is much there that would cause a high level of heat, but you could always check the connections at the switch to make sure.
mcaanda
Apr 27, 2010 01:00 PM
01_fast_ride
Jun 4, 2007 07:20 PM
euro3b
May 17, 2007 10:37 AM
euro3b
Apr 20, 2007 04:43 AM
reillys70
Sep 9, 2006 05:24 PM
