P1633 code
Old Jun 9, 2008 | 02:36 PM
jiveturkey's Avatar
Default P1633 code
Not sure if this has been psoted but if so I apologize for restarting. I have been getting the ABS?STC as well as check engine light and service light coming on every now and then. I scanned it with a ACTRON OBD II and it pulled up this code P1633 Manufacture Control Auxiliary input/ output. Does anyone know what this may mean?
Old Jun 9, 2008 | 05:51 PM
Default RE: P1633 code
It is most likely a speed sensor code coming from a bad ABS module.
Not 100% sure don't have my p code list in front of me.
Old Jun 9, 2008 | 09:34 PM
air force rascal's Avatar
You're right TECH Speed Sensor....you nailed it !!!
Old Jun 9, 2008 | 10:39 PM
A bad ABS module will send a code to the ECM when the module goes bad.
Old Jun 9, 2008 | 11:06 PM
jiveturkey's Avatar
How would I go about fixing that? Does that by any chance have to do with a ABS Mdoule? I am having similiar problems that was listed in one of the forums concering the CEL.
Old Jun 10, 2008 | 06:13 PM
Yes a bad ABS module will set the code in the engine computer.
Old Aug 3, 2010 | 06:57 PM
parrothead71's Avatar
Is there one sensor or is there a sensor at each wheel? I have the same code on my 2000.
Thank you
nashdavea
Jul 24, 2013 07:29 PM
parrothead71
Aug 4, 2010 07:18 PM
Mutley530
Oct 2, 2009 10:25 AM
dlaman
Jul 3, 2008 07:29 PM
