Rear bumper removal - safe?
Old Jun 12, 2010 | 07:37 AM
dwimorberg's Avatar
Default Rear bumper removal - safe?
Hi guys, I'm installing a tow hitch to my S80 and I need to remove the rear bumper to cut a hole in and get it fitted more easily. The instructions that come with the hitch are pretty sketchy in details.
Is it safe to remove the bumper as far as the airbags are concerned? I'm guessing there must be some airbag sensors in there somewhere. Is it possible to temporarily disable them?
Many thanks in advance for your help!
-Mikey
Old Jun 12, 2010 | 05:32 PM
beefheart's Avatar
what year? my 2000 looks like all one would need to do is make a few measurments and create a templet and use a saws- all with a fine blade, but anyway, first things first, what year?
Old Jun 13, 2010 | 09:05 AM
dwimorberg's Avatar
Hi there, thanks for the reply
It's a 2005 model, I've just had another look through the instructions for the towbar and you seem to have to take off the bumper to insert some metal pieces with a nut in them through some holes too. I wonder if this is accessible without taking it off? I can't check at the moment as I've hurt my back
Here's a link to the instructions:
http://www.westfalia-automotive.de/f...%2013.8018.pdf
Page 7 has the bit with the nuts.
Cheers,
Mikey
Old Jun 13, 2010 | 07:03 PM
beefheart's Avatar
those are pretty darn good instructions, if you are handy with a socket set and a few other hand tools you should have no problem, feel free to ask more questions on this matter if you get in a tight spot, best regards, beefheart
Old Jun 19, 2010 | 01:06 PM
dwimorberg's Avatar
Hey Beefheart, many thanks for your help
I finally got it all fitted up today, took a lot longer than I thought but I guess that's what you get for DIY The only hard bit was actually getting the rear bumper removed, but only because I wasn't sure what I was doing! I was worried about there being airbag sensors in the bumper but either there wasn't one or it was disabled with the battery disconnected.
All in all though, I'm glad it's finished! Just the rivets to go back in the wheelarch now.
Thanks again for your help,
Michael
Old Jun 19, 2010 | 01:46 PM
beefheart's Avatar
good for you, glad that you got it done! best regards, beefheart.
pimble2005
Aug 26, 2013 04:55 AM
aytchgee
Mar 18, 2013 11:33 AM
ibified
Jul 19, 2010 11:04 PM
s70_t5_1999
Jan 24, 2009 01:01 PM
