Rear oxygen sensor ?
Old Apr 1, 2018 | 04:33 PM
e.mence440's Avatar
Banned
Default Rear oxygen sensor ?
I got a check engine light on so I checked hooked up my scan tool and got a trouble code for a rear oxygen sensor. Does anyone know where it is located and can I replace it myself. My S80 is a 2000 T6 twin turbo. I've changed O2 sensors on the GM vehicles before , just never had to on a Volvo yet. Car only has 129,000 miles on it.
Old Apr 1, 2018 | 06:50 PM
the O2 sensors are plugged into the downpipe(s) before the catalytic converter and in the exhaust pipe after the cat. The front is used for fuel trim, the rear is to measure cat efficiency. Does your model have four O2 sensors? If so you'd need to look at the code to see if its bank 1 or bank 2 to know which one it is.
Old Apr 1, 2018 | 07:02 PM
e.mence440's Avatar
Banned
The exact code is ECM-2a2a
Old Apr 2, 2018 | 07:27 AM
tony1963's Avatar
The rear oxygen sensor is mounted in the converter and they are a lot of work to change. Plan on removing the catalytic converter to get to it.
Old Apr 2, 2018 | 10:11 AM
thommykent's Avatar
P0141 ECM‑2A2A Rear heated oxygen sensor (HO2S) Faulty signal preheating
List of Codes:
https://www.matthewsvolvosite.com/vo...nd-newer-codes
soduku007
Oct 7, 2019 04:01 PM
habbyguy
Nov 10, 2014 07:01 PM
tomservo
Nov 27, 2005 11:50 AM
netflash
Jan 31, 2005 07:56 PM
