Replacing Corner Turn Signal Installation Problem
Old Mar 2, 2008 | 03:10 AM
Linksman's Avatar
Default Replacing Corner Turn Signal Installation Problem
I am trying to replace my left side turn signal lens housing but the OEM volvohousing replacementis different from the one being taken out.The new housings do not install flush orclip in.Theyis something hindering the housing to fully seat.Hasanyone had the same problem trying to install new housingson a 2000 S80? Do I need to modify the bracket somehow? THANKS, Christian
Old Mar 2, 2008 | 07:09 AM
Default RE: Replacing Corner Turn Signal Installation Problem
Look at the pin in the top of the light.
Alot of times the replacement one is a bit bigger. Then you will have to open the hole on the body side a little more to make it seat all the way.
LandonJBennett
Jun 6, 2011 12:23 AM
crosby1
Apr 15, 2010 08:17 PM
winchargerman
Feb 25, 2010 05:59 PM
johns_volvo
Dec 2, 2009 08:31 PM
eric1164
Jan 19, 2008 10:41 AM
