rough idle
Old Feb 3, 2009 | 01:37 PM
abflip567's Avatar
Default rough idle
I have replaced all spark plugs, checked all coils for conductivity, and they all check good. The other thing is that my car is throwing a code for a random/ multiple cylinder misfire, i was wondering if this would be because of the fuel injectors? if so, is there any good step by step instructions out there to replace these because i have looked on VADIS and there is nothing good enough.
Thanks
Old Feb 3, 2009 | 01:52 PM
bcampbe7's Avatar
I had a Land Rover that did this and it was caused by bad plug wires.
The way I found it was to run the vehicle at night in a very dark area. When I fired up the vehicle and popped the hood it looked like a little light show under there. Replaced the wires and all was good.
Not sure if you have replaced the wires or not. If not, check them out.
Old Feb 3, 2009 | 02:05 PM
abflip567's Avatar
i have checked all the coils and they are sparking to the frame when i tested them, so i am assuming that if the coils are sparking to the frame that all of the wires are good enough, thank you and if you know of any other solutions i would be glad to check them out.
Old Feb 3, 2009 | 02:07 PM
bcampbe7's Avatar
I also had spark, just not very efficient.
nkinkade
Feb 28, 2014 08:49 PM
rosesforlily
Nov 5, 2009 09:23 AM
yank50
Mar 14, 2009 11:15 AM
Tech B
Oct 28, 2004 09:34 PM
