S80 1999 Transmission
My Volvo s80 1999 recently replaced another used tranny ...which is very good while normal drive ..a minor jerk which driver can feel...but while speeding there is a slipping like if I increase the throttle ....from 20KM/h to 40 KM/h and then at 160 KM/h.
Today I changed its oil with Castrol Dexron III. I did found some debris in the pan. Any idea guys what actually happened to my tranny or i just ignore it. |
If you Replaced it with a used one my guess that you would require a software update (dealer only). Being that most of those trannys are not plug and play. Do you hav a check engine light along with a transmission service message?
No there is no message on dash?
And how much does it cost to update from dealer? |
Not sure they do charge per hour like 85 or more, i could b wrong, but they will check by the symptoms ur noticing, but be aware they most likely said also that u need a new tranny, typical of them.
Presented returning in the season 1999, the Volvo S80 is another high-class car from the Volvo product. It is a front side rim generate automobile and has been introduced in the marketplace so as to substitute the Volvo 960 automobile which was already of the mature years.
