S80 1999 Transmission
Old Aug 17, 2012 | 09:53 PM
majorcode's Avatar
Default S80 1999 Transmission
My Volvo s80 1999 recently replaced another used tranny ...which is very good while normal drive ..a minor jerk which driver can feel...but while speeding there is a slipping like if I increase the throttle ....from 20KM/h to 40 KM/h and then at 160 KM/h.
Today I changed its oil with Castrol Dexron III. I did found some debris in the pan.
Any idea guys what actually happened to my tranny or i just ignore it.
Old Aug 18, 2012 | 04:42 PM
gabyman97596's Avatar
If you Replaced it with a used one my guess that you would require a software update (dealer only). Being that most of those trannys are not plug and play. Do you hav a check engine light along with a transmission service message?
Old Aug 19, 2012 | 12:47 PM
majorcode's Avatar
No there is no message on dash?
And how much does it cost to update from dealer?
Old Aug 20, 2012 | 08:19 AM
Not sure they do charge per hour like 85 or more, i could b wrong, but they will check by the symptoms ur noticing, but be aware they most likely said also that u need a new tranny, typical of them.
Old Aug 24, 2012 | 12:50 PM
meronleaon's Avatar
Presented returning in the season 1999, the Volvo S80 is another high-class car from the Volvo product. It is a front side rim generate automobile and has been introduced in the marketplace so as to substitute the Volvo 960 automobile which was already of the mature years.
koziolek
Sep 19, 2016 03:26 PM
kpmp64
May 6, 2012 05:19 PM
cbcustoms
Aug 12, 2011 01:20 PM
7antera
Jun 2, 2008 08:00 AM
gratefulvolvo
Dec 9, 2007 04:30 PM
