S80 Emmissions Service Message
Old Oct 20, 2006 | 03:09 PM
Clem38's Avatar
Default S80 Emmissions Service Message
1 day before taking my 2001 S80 in for it's 60K check (actual miles 65K), I got an "Emmission System Service Required" error & "Check Engine". The dealer ran Diags and said results were "internal failure of the variable valve timing unit". Recommendation was to replace CVVT unit and solenoid, obviously estimated at over $1000. Is this typical for that many miles? and Any other options/things to check before I drop the money? Thanks.
Old Oct 20, 2006 | 08:40 PM
studd34000's Avatar
Default RE: S80 Emmissions Service Message
if it sounds like a misfire or somthing i would check the coils over the cylinders just in case
Old Oct 20, 2006 | 10:16 PM
Ihatespeedbumps's Avatar
ORIGINAL: studd34000
Doubt it's a misfire. Misfire codes are usually VERY specific with these newer cars.
To the original poster: Usually just replacing the solenoid (with gasket of course) will fix the problem. I would start there, and if the problem persist then replace the CVVT unit.
Old Oct 21, 2006 | 01:35 PM
Also make sure the timing belt didn't jump a tooth.
malaka
Aug 10, 2010 06:38 PM
benithegreat
Feb 10, 2009 05:57 PM
saibari
Nov 28, 2007 10:30 PM
kdonnelley@sbcglobal
Nov 14, 2006 04:39 PM
jwstephens2002
Jul 9, 2005 06:57 PM
