S80 Low Beam insultor replacement problem
Old Feb 25, 2011 | 02:35 AM
vy22's Avatar
Default S80 Low Beam insultor replacement problem
I have a S80 T6 1999. The low beam was dead. When I try to replace the light bulb, I found the socket (the plastic insulator) of the bulb was partially burnt (the brown one on the left in the attached photo). I ordered a replacement from the dealer (the black one on the right). The part number is: 8678122. Is this correct? But no matter how hard I tried, I was unable to push the connector into the new insulator.
I took it back to the dealer. The guy from the parts department insisted it was the correct part. He offered to ask the mechanic to replace it for me for $40. I said OK, If you can insert the connector into the new one, I'll pay you $40. 20 minutes later he came back and said they couldn't put it in. He said Volvo must have change the design. But according to the computer, 8678122 was the correct part number. True?
I noticed the opening for the connector in the old insulator (the yellow rectangle) is noticeably larger than the one in the new part (the red rectangle). That's why the connector could not be insert into the new one.
Any suggestion?
Attached Thumbnails S80 Low Beam insultor replacement problem-s80-head-light-b.jpg
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
volvo40_2k
Jul 28, 2009 09:18 PM
ltljon
Jul 28, 2009 07:44 PM
Jay Bee
Aug 4, 2008 04:33 PM
blkntr
Jan 4, 2008 09:05 AM
