S80 T6 2000
Having a problem with my STC. When it is on and I make any turns, it causing a loud noise around my driver side wheel. Can anybody give me a guess at what it could be? When the STC is off, no noise at all.
RE: S80 T6 2000
Could be either a bad ABS sensor or a bad abs module.
RE: S80 T6 2000
Why are the STC and ABS systems so connected? I don't understand how the braking system and traction control can be linked.
RE: S80 T6 2000
They are linked together.One stops the wheel from locking up while breaking and the other stop the wheels from spinning freely.
It is all sensed from the ABS wheel sensors.If one wheel is going alot faster than the other the STC kicks in. If the sensor is dirty or bad the reading will be off. |
RE: S80 T6 2000
To Lorawms or any one else who has had this problem; I am having a very similar problem with my 99 s80. A loud grinding noise coming from the driver side when I turn. It seems to have just started after going though some deep snow and running over hidden concrete bump that was not marked. While I am planning on taking the car in to be checked out as soon as possible, I was wondering if it is possible that is something this simple. I read in another forum that this noise may be normal. We have had plenty of slippery days here so far this year and I have never hear this noise so I am a bit worried.
Thanks for any help you guys can give. |
