s80 thermostat tube
5 Attachment(s)
I just got done with the 2002 s80 thermostat overflow tube.
as some of you know they break very easy when going to remove timing belt cover. I drilled the old one out with a letter R drill and tapped the hole with a 1/8 pipe tap. I used a 1/8 90deg compression fitting and about 1" piece of 1/4 tubing. I did modify the cover as my pic shows as to put a hose clamp on it after cover was installed |
nice job!!!
thanks, I got the idea from this forum, so it does really help out
