S80 troubles
Old Oct 3, 2015 | 02:33 AM
Speedy Gonzales's Avatar
Default S80 troubles
So my step daughter gives us a 01 S80 that just quit running , after inspection found power steering pump pulley desintergrated & serpentine belt shredded and wrapped itself around crank. After removing and replacing pump & belt engine turns but no start, will backfire now & then. Found wiring to 1st ignition coil on passengers side seems kinda melted . Could this be the problem? Is it normal for wiring to appear a little melted ? Any info greatly appreciated.
Old Oct 3, 2015 | 01:19 PM
ES6T's Avatar
Timing is most likely out, bending valves.
Old Oct 4, 2015 | 12:30 AM
thank you for the confirmation as I was told the same just earlier today from a newly acquired source. I wonder how one would confirm the bent valves ? I suppose it's necessary to actually tear the motor apart ?
Old Oct 4, 2015 | 07:08 AM
ES6T's Avatar
Or re-time it and then do a cylinder leakage test if it doesn't start.
Old Oct 4, 2015 | 03:15 PM
[QUOTE=ES6T;419663]Or re-time it and then do a cylinder leakage test if it doesn't start.[/QUOTE thank you very much for the information I will try it and get back to you with the results I can't tell you how much I appreciate the help
dragonz
Nov 9, 2008 08:23 PM
Lichty17
Sep 25, 2005 11:54 PM
Paul1
Sep 10, 2005 01:57 PM
harvey
Jun 22, 2005 03:51 AM
Big Daddy
Oct 24, 2003 09:46 PM
