Sensor locations
Old May 1, 2015 | 12:37 PM
Myka's Avatar
Default Sensor locations
My dad needs some help locating the following sensor locations on his 2002 S80. He was given these codes and told they were possibly sensors that need to be replaced. Any help would be greatly appreciated. He really cant afford to take it to a shop since my moms in the hospital.
711A control module internal fault
280A Front Heated O2 Sensor B1
644A cam shaft position
641A exhaust cam shaft control
Old May 1, 2015 | 02:48 PM
The 711A is saying there is a signal problem into the ECM. This could have been set by a battery issue/alternator issue/wiring or the ECM itself. First step would be to see if you can clear the code and see if it represents.
The 280A is saying the O2 sensor went out of range. This could be that the O2 sensor needs to be replaced or something else is pushing the system - ie vacuum leaks can show up as O2 sensor issues
The 644A and 641A are related to the variable valve timing (VVT) - there's both a valve position sensor as well as a solenoid - either can mess up the valve timing (and throw the codes). The VVT solenoid and position sensor should be on top by the #1 cyl
Old May 1, 2015 | 04:51 PM
ES6T's Avatar
Guessing can be just as expensive as taking it to a shop. I would not replace the can position sensor for those VVT codes.
Old Mar 26, 2023 | 05:53 PM
sirdani's Avatar
I have the same code on a S80 2002. Have you fixed your ECM-711-A? If yes, how?
autosys1
Feb 2, 2015 07:25 PM
Krle
Apr 1, 2010 03:33 PM
Dr. Mordo
Nov 22, 2008 09:45 PM
FrancisD
Jul 17, 2008 06:38 PM
exodus454
Apr 2, 2008 08:30 AM
