should I delete the Error code
Old Mar 24, 2022 | 01:06 AM
bill922's Avatar
Default should I delete the Error code
My S80 Volvo car check engine light is on, i used OBDII device to test, it shows code P0305 cylinder 5 misfire detected, then i found the issue is indeed from spark plug. after i change the spark plug, i used OBDII device to delete code, is this not correct? i am told i should not do anything, the car will remove it automatically. now the thing is i don't know if it is really fixed or not, because the check engine light is not on any more, is it fixed? or it is because i removed the error code? thanks.
Old Mar 24, 2022 | 08:15 AM
Yes always delete codes, unless you are taking the car to get fixed and someone else needs to see them. The check engine light will go out if all codes are erased.
If a problem still exists the code will come back. And some codes won't erase by themselves - SRS codes are an example of that.
bill922
Apr 20, 2023 11:12 AM
cameyb
May 29, 2011 03:41 PM
Volvaman
Jan 12, 2011 01:07 PM
eddyxwb
Jul 29, 2009 06:51 PM
chimmychong
Apr 3, 2008 11:01 PM
