Starting / Starter Question
Old Dec 28, 2010 | 01:11 PM
smithud91's Avatar
Default Starting / Starter Question
Turn key to start car. Lights/Radio work normally. At final twist of key when you would expect to hear engine crank over........nothing. Battery removed and tested as fully charged. Starter removed anticipating it was bad but it too bench tested just fine. Starter relay I'm thinking? It checks out electronically just fine. Battery connections look clean. Ground in trunk looks clean. Positive under hood looks clean. The only item I can think of is the Ignition switch? A bit of a mystery so any ideas would certainly be welcome. thanks so much
Galaxy850Sunny
Jan 22, 2015 08:45 AM
lapwizrus
Jul 11, 2009 01:25 PM
mjwaterma
Mar 19, 2009 01:07 PM
geminiys
Oct 9, 2007 12:17 PM
