subframe orings or lower control arm bushings?
Hi, I have a 2000 s80, w/ mostly left front clunk, it has 129k, In last 20 K,I did struts, seats, seat bearings, tie rods, sway bar links, still a clunk.
I am running out of stuff to ck/ swap? I am thinking subframe orings next. Frowm what I read so far, loosen a few cradel bolts, drop back ones, pry cradle down, slip in o ring. Is it this easy? How common is the control arm bushing failure? Thanks, Dave |
RE: subframe orings or lower control arm bushings?
Control arm bushings pretty common. I would check them first.
The o-rings aren't all that bad. |
