subframe orings or lower control arm bushings?
Old Jul 7, 2008 | 12:35 PM
cudavid's Avatar
Default subframe orings or lower control arm bushings?
Hi, I have a 2000 s80, w/ mostly left front clunk, it has 129k, In last 20 K,I did struts, seats, seat bearings, tie rods, sway bar links, still a clunk.
I am running out of stuff to ck/ swap? I am thinking subframe orings next. Frowm what I read so far, loosen a few cradel bolts, drop back ones, pry cradle down, slip in o ring. Is it this easy?
How common is the control arm bushing failure?
Thanks, Dave
Old Jul 7, 2008 | 06:19 PM
Default RE: subframe orings or lower control arm bushings?
Control arm bushings pretty common. I would check them first.
The o-rings aren't all that bad.
mike21070
May 18, 2015 01:10 AM
Lee Lacy
2001-2013 model year V70
Mar 23, 2014 05:12 AM
Platinum52
Jul 17, 2009 07:33 PM
ludeless
Dec 16, 2008 07:21 PM
sy381
Jul 2, 2008 07:33 AM
