sun roof jamed
well this week is not my week first my headlights stop working then my sun roof will not colse i dont know what it could be it acts as thou its jamed because it will start to close like 20% then it will just stop
RE: sun roof jamed
Try locking and unlocking the car with the key/remote and then see if it will close.
RE: sun roof jamed
i tryed that so i think that i need to take apart my roof lining to check whats causing the jam so can you give me instructions on how to do that??
RE: sun roof jamed
It is a pain to remove the Headliner.
You will have to remove all handles and Domelight assembly. The remove the rear clips by the back window.Turn then and pull and they should fall out. Then you might have to take the entire assembly out of the roof to find out what is wrong with it. |
RE: sun roof jamed
are you serious is it way bad or is there another trick i can try??
RE: sun roof jamed
Maybe just play with it.
Do you hear any funny noises when it moves? |
RE: sun roof jamed
nope it just closes slightly then stops
RE: sun roof jamed
Maybe just out of time.
But to check the computer might be able to see but mainly only the dealer can check. |
RE: sun roof jamed
It might be software!?!?
RE: sun roof jamed
really did your car do this also and i really want to thank everyone for all of the help you guy's are great
RE: sun roof jamed
It didn't have this specific issue, but it can behave quite oddly. The software issue I ran into left my blinkers not working and my message reader on the dash not working correctly. This all occured literally overnight, and was remedied after I took it to the dealership and had them load all new software.
RE: sun roof jamed
I have it were when the driver door was opened, the sunroof and windows did not act right. Make sure the drivers door is closed. Fixed my issue. -R
RE: sun roof jamed
well i went down to the dealer today and we tried to reset the setting to see if that would help but i did not so i just want to ask tech after i took off the roof lining how would i manualy move the sun roof??
RE: sun roof jamed
Look and see if the motor has a slot in it. Like that you could put a screw driver into.
