Sunroof help needed
Sunroof help needed
So... My sunroof was working fine until a few months ago..
The first problem I had was that when I set it to close, instead of stopping at the closed position it would go automatically past the closed and to the rear lifted position..
With manual adjustments and patience, I could get it to close as it should.. Recently however when I press the sunroof control, nothing at all happens.. Any ideas on what we could be dealing with?
I have heard that the alarm module is somehow linked to the sunroof (strangely) and I know that mine is bad, so could that be a potential cause? On the other hand, could one of the guide rails be off, or worse yet could the motor have simply died? Do you all have any diagnosing tips?
Well, if I recall coming down to the last few times it still worked it woold make a slight popping noise if taken all the way in the UP position..
Now it just doesnt move at all.. That said, I have a new observation..
Even though it doesnt move at all with the controls, it sometimes gives a little bit of audible noise if I hit a bump... like a sort of pressure change noise as if the sunroof itself just barely opened or "jumped" on its tracks for a split second, then back to normal..
Strange occurrences, and I guess I need someone who knows volvos to take a look and see whats up.
more $$
more $$
thegazelle
07-22-2019 11:00 PM
nnamssorxela
08-28-2010 05:26 PM
